Posted: Aug 13 2005 at 9:18pm | IP Logged
Motor and ECU... I believe the mount points were the same. And the tranny is a bolt up... at least the tranny codes were the same. So I assume it's a direct bolt up.
Mr. Merritt Groupie
Posted: Aug 13 2005 at 11:00pm | IP Logged
so should i not try to find the motor with transmission.
__________________ 2001 Frontier Shortbed XE
Four Cylinder Manual
Posted: Aug 14 2005 at 1:22am | IP Logged
I'd get one on the safe side. Newer so hopefully less problems. But stuff happens
Mr. Merritt Groupie
Posted: Aug 14 2005 at 1:23am | IP Logged
alright. there are apparently 3 kinds of engines that are ka24de's.
im completely thrown off now. my truck has one in it. but so do 240sx's. and altimas.
someone explain the difference in them. now i just see them all as equals.
Posted: Aug 14 2005 at 5:36pm | IP Logged
There is no difference in the motors. (except maybe the intake) The heads and block are the same.
Wait... I could have sworn the DEs didn't come out till 2002. If your's already has the DE version... the defintley check www.jimwolftechnology.com Pistons, cams, etc. You could even put on a turbo.
Mr. Merritt Groupie
Posted: Aug 14 2005 at 7:51pm | IP Logged
awesome. i dont have to buy a whole new engine to get cool stuff.
thanks
but im sure this topic is not over yet. i keep coming back.
Posted: Aug 14 2005 at 10:23pm | IP Logged
I'm jealous... you have a manual in yours. Oh well, I like to cruise with mine.
I just bought new tires. Goodyear Wranglers. Man my truck looks weird. It actually almost looks like a 4x4. I'll post pics up as soon as I can.
Mr. Merritt Groupie
Posted: Aug 14 2005 at 10:44pm | IP Logged
im gonna steer away from the 4x4 look, since ive already gotten stuck in some mud.
i plan on lowering it. bigger rims, lower profile tires. nothing too showy though.
Posted: Aug 17 2005 at 7:43am | IP Logged
That's my plan as well, but I need the tires for winter around here.
Mr. Merritt Groupie
Posted: Aug 17 2005 at 11:12pm | IP Logged
actually. i think im keeping the stock rims. i dont feel like trying to find a 6 lug rim that i like that has the same. uh. offset.
the spindles i found have to have the same offset as the factory wheels. or theyll break.
but its all good. i like the overall stock look. i mean, itll be lower to the ground, but it wont make it seem like im trying to pimp it up or rice it around. or whatever.
