Amandabee Newbie
Posted: Aug 04 2016 at 9:08pm | IP Logged
jjski78 wrote:
Here's the process to reset the air bag
light. I tried it and it works.If you have the airbag
light, it will show steady for a few seconds (the manual
says 7 secs) after you turn the key from off to on (but not
start) and then start to flash. Here is how to reset it:1.
Turn the key from off to on.2. Watch the airbag light
closely. It will stay on for a few secs. and then as soon
as it blinks off (the start of the flashing), turn the key
off instantly.3. Count to 5 (1 Mississippi, 2 Mississippi .
. . .)4. Repeat steps 1-3 two more times until you have
done the cycle three times.5. Now turn the key on and watch
the light. It will start blinking in a different, slower
manner. This is diagnostic mode. You can watch this for a
little while, no hurry.6. Now turn the key off again, Count
to 5 like in step 3 again, and turn back on. If the
procedure worked, the airbag light will not be flashing.If
it does not work the first time, just repeat the steps
again. |
Thank you! This was the first link i chose
when i did a search for a possible cause after our airbag
light randomly started flashing while we were going down
the road. Thank you so much for your post. It worked like
a charm
Posted: Aug 05 2016 at 1:30pm | IP Logged
Thanks for the Thanks!
Sites like this don't get enough...
Thanks again.. Don S..
