Synthetic Oil Newbie
Posted: Aug 20 2007 at 12:03am | IP Logged
If you want to see some testing comparing AMSOIL and Mobil 1 then go to this site: http://www.genuine-synthetics.com/AMvsM1.html
And then there is testing of about ten different oils including AMSOIL and Mobil 1 Extended Performance: http://www.amsoil.com/performancetests/g1971/index.aspx?ZO=1 513149
The only testing that I am aware of that includes Royal Purple is of motorcycle oil, but the results should be somewhat relevant to their vehicle oils: http://www.amsoil.com/lit/g2156.pdf?ZO=1513149
Make no mistake, not all oils are created equal.
__________________ '07 Frontier SE 4x4 CC
Oklahoma City
tonkasc01 Newbie
Posted: Sep 01 2007 at 9:44pm | IP Logged
Royal P is good i now one of the paper companies here uses it on the big machines and Mobil is what i use the breakdown is differnet for the area and what weight you use 5 is most commom but 10 is good and the best oil as far as conventinal is what has the least amont of wax in it that is penn state oil any thing from Penn. the syn stuff is about the same just check and see what deturgent are in it some are for dirty trail runner and others for long highway miles it's up to you
the army use to recycle their oil back in the 30's-50's idk about 2day but recycle oil is the cleanest you can buy the least amount of wax and detergents that keep the old jeeps and detroit deisels going
__________________ 2k1 Nissan Frontier SC CC SB
2k6 Toyota Camry LE V6
Frontyfan Senior Member
Posted: Sep 04 2007 at 12:45am | IP Logged
i would agree that not all oils are created equal, however, i would venture to say ALL oils, virtually, will go 4k easy including conventional dino oil. synthetics longer for sure, some say that if you have OCI's shorter than 5k with synths, you are just wasting money. I still haven't made up my mind on that issue as i believe it would depend on driving conditions, environmental conditions, blah blah blah.
however, if you are going to compare oils and look at "test" data, sorry amsoil guys..don't go looking at sites run by independent distributors or whatnot. i have not heard anything bad about amsoil, but for some of y'all to be posting in response to almost any problem that amsoil will fix it, then why not offer a free OCI for some people so they can run an extended OCI and see if they notice a huge difference.
Amsoil and royal purple may very well be "superior" oils, but for most people, including myself, i dont' see myself here in south texas running 10k on any oil and running a run of the mill oil synth such as PP (penz. platinum) or M1 for 5k-7500 miles will be just fine. if one wanted to get the real tale of the tape, then oil analysis would indicate better wear metals, TBN numbers that don't plummet, viscosity numbers that don't go outside of grade and don't drop significantly to indicate resistance to shear.
S.A.R.Tech Senior Member
Oil Tech
Online Status: Offline Posts: 122
Posted: Sep 06 2007 at 8:58pm | IP Logged
hmmm
sounds like the usual. Who here has the money to run oil analysis'? I just put in the infamous Amzoil and decided that I will watch it like a hawk and change filters every 5k and go for the 20k kms run. According to the Amzoil info, that is still 17k kms inside of their recommended oci. I feel taht is still a very substantial safety buffer. I do agree with the cost assessment too. That's why I am running like this. I should be able to make the oil pay for itself that way. I have not found a lab for oil testing here in Calgary. So, for now I'll just trust like a dummy and wath the fuel mileage and stuff. Wish me luck.
__________________ firefighters don't need to compensate, they just kick ass
Posted: Sep 08 2007 at 11:50am | IP Logged
Oil analysis isn't as expensive as you think, and you know having one done is beneficial, there are sites out there where you can gather information on virgin oil analysis as well as used oil analysis, but the used oil analysis are more helpful to your specific vehicle when done on your oil obviously.
I guess my main point was this, anyone running a certain oil cause it has worked for them will say "you can't go wrong" with brand X, it does me right. Hell i used to use Castrol GTX in my old 240SX all the time, because my dad used it all the time in their vehicles, and it never failed me, and i abused the hell out of it, and drove the car hard. If you look at Amsoil's site even, you see their oil compared to other ones and Castrol GTX is right up there in the ballpark with the synthetics in a lot of the properties they test. (and it's 2.**/qt) Now I use Mobil 1, cause i never heard anything bad about it and wanted the "extra" protection of a synthetic. it should hopefully resist shearing better than dinos. Whether that is the case, I will hopefully learn. Even tho I could justify the extra money on M1, I couldn't justify the added cost of RP or Amsoil, and there is no way I'd run my engine for a year on ANY oil as some manufacturers tout their oil can do. i think i've mentioned before that a buddy of mine at work uses nothing but the cheapo wally world stuff in his ranger that has over 300,000 miles on it...of course he is a mechanic by trade and always does 3000k changes on his oil and i think he uses cheapo tranny, gear oils and stuff too. he just feels like it will last as long as he's on top of the maint. he also swears by marvel mystery oil and puts it in his engine. Bottom line is, if the oil works for you and your vehicle, use it.
btw, prices on synths around here have come down recently which is nice to see....a couple bucks maybe but that's a couple bucks saved i guess lol.
Boomer Senior Member
Posted: Sep 08 2007 at 2:49pm | IP Logged
SOme comments from an organic chemist on synthetic oils. First, the molecules are engineered to have a very narrow MW range and so are all similar. There are no little moecules to boil away right after you change the oil. And there are no large wax-like molecules to help form sludge. And with all good synthetics there are no double donds present that can be subject tp oxidative polymerization that forms a hard crud. This is similar to the chemistry of old oil paints when they dry. Synthetic oils are generally poly-alpha-olefin (PAO) or a type of polyester fluid. Mobil 1 is a blend of these.
But you do have one issue that I am aware of with synthetics. Mobil 1 does not use certain zinc compounds and as such it is particularly good on maintaining the long term activity of your catalytic converter. Some of the other oils do use this ( they use it because they need it to prevent wear) and these oils are not recommended for your by the American Petroeum Institute for long term catalytic converter activity.
Oil Tech
Posted: Sep 13 2007 at 12:35am | IP Logged
I have heard of the Marvel Mystery Oil suff a few times and thought it was
the stuff of legends. I guess not.
I have ot admit though, that a lot of what the Amsoil peopel spout sounds
like good logic to me. I think they are out to liunch on their air filter
stuff, but who knows.
I was able to track dow three labs locally to analyze my oil after talking to
a amsoil rep at a 4x4 show last week. I'll go get it done. I'm still going to
change my filter though. He clamis that the oil and filter from them are
good to 40000km no matter what, i seriously doubt it.
as a point of interst and comparison, my girlfriend owns a new (three
hours older than my truck) chev cobalt with an oil ife monitor system on
it. She runs QS and the monitor made her go 20000 before her first
change. I gues it runs on oil temp, not viscosity. And she has no prolems
at all, from dino! so how much further could a good synth go? I have got
a little skittish and told her to let me change it at least every six months
from now on, and explained to ehr why. So I guess we'll see.
I am going to change my oil strictly based on the analysis from now on
and see where that takes me. I am going to run two levels of the amsoil
then switch brands and see which comes out on top. I can actually get
red line here too, so that'll go in next, and start moving down the line.
Should be an intersting couplep of years. I would publish the resulots of
each oil analysi if you guys would like to watch things unfold. I'll also
include the type of driving n each segment, imcluding all pertinent
variables. Then we'll all know, at least for our trucks.
Posted: Sep 13 2007 at 12:21pm | IP Logged
Lots of opinions out there. Very interesting. Synthetic oils will not break down due to the inherent nature of their structure. The limiting factors when running synthetic oils is that the additives will eventually get used up and water will eventually accumulate. Particulates also accumulate. The filter will take care of the particulates but the water and additive issues require replacing the oil to fix. How do you know when it's necessary to replace your synthetic oil? One way is oil analysis. Oil Analyzers, Inc. will do this testing for around $15-$20 depending on shipping. However, if AMSOIL says their oil, when used with their filters, will last for a given amount of miles, you can bet they're accurate or they couldn't offer the warranty they do. AMSOIL has the best warranty in the business (http://www.amsoil.com/lit/g1363.pdf?zo=1513149). If your engine is damaged as a result of using AMSOIL under their drain interval guidelines, they will pay for your repairs or replace your engine. After my experiences using AMSOIL, I will never use dino oils again. There are so many benefits to using synthetics that dino oils can't provide (http://www.genuine-synthetics.com/benefitsandfeatures.html). As for any oil whether it be dino or synthetic lasting 4-5K miles without any problems, that is most likely true. However, if I can use AMSOIL and go 3-4 times longer and still get better engine protection, it seems like an easy choice for me. As far as the price of AMSOIL being higher than dino oil, AMSOIL offers a preferred customer membership (http://www.genuine-synthetics.com/PC.html) that allows you to buy products at a 25% discount and the cost of the membership is only $20 per year. If you spend at least $100 per year on AMSOIL products the membership pays for itself. And with the membership comes a subscription to AMSOILs montly magazine, The AMSOIL Action News. I have been using AMSOIL for three years now and usually go the full year between oil changes. I do oil analysis at about the 9 month point and am always still in good shape in terms of oxidation, viscosity, nitration and contaminants such as water, fuel dilution, glycol and solids. You must use their high capacity, nanofiber oil filters(http://www.amsoil.com/filtration/index.aspx?zo=1513149) if you don't want to change the oil filter during the drain interval. If you do use a different filter, I would recommend changing it every 3K miles which will require you to top off the engine oil. That would also help your oil quality because you are adding fresh oil every 3K miles. Still, it's cheaper to buy the AMSOIL filter and let it go the entire interval. I have not had any problems with this. I know us guys love our vehicles and like to work on them and take care of them by doing regular maintenance, buy to use a synthetic such as AMSOIL and still replace your oil at shorter drain intervals is just waisting money and creating excessive oil waste. Another great thing to mention about AMSOILs 100% synthetic motor oil is that is 100% created in the USA and does not contain a drop of foreign oil.
Oklahoma City
Posted: Sep 14 2007 at 1:55am | IP Logged
In the interest of full disclosure synthetic oil, are you a distributor of the famed Amsoil? Also, Oil Analyzers is owned by Amsoil isn't it? Not trying to bust balls, but I just think it's fair to note, I disclosed that I am a Mobil 1 user. How did I come about this decision, well before I learned about oil analysis and all that good stuff, I was a Cast. GTX user religiously, why because it always worked for my father as I said before. Even by Amsoil website comparisons, GTX is right up there with the synthetics in test data. I went with Mobil 1 based on that I have never heard anyone really really crap on it's performance and wanted the "extra" properties of synethetic oil. That could be from additive packages that are put in for anti-wear or of the detergent/dispersant variety. Or the fact that it is (depending on the oil) a blend of PAO base and others such as Group IV, or III. In all actuality, it is the combination of those factors that make synthetics superior as far as extended OCI's in my opinion. Different manufacturers use their own version of additive packages and are constantly refining them to improve the oil longevity and ability to protect engines.
I am going to be getting UOA's done on my truck as well, simply because I want to know what the lifeblood of my engine is doing in there. It will definitely be interesting to note if you post your data SAR on UOA's with diff brands of oil. I will also post data if you guys would like to see it.
As far as still wanting to change your filter even on extended oil changes, I dont' see any problem with that, in fact I would err on the side of caution and do that myself if I was going to run over 5-6000+ miles on an oil change. Also when you do that and are forced to top off with fresh oil, synth was right in stating that you might be getting better protection because you are adding fresh oil to the mix, although you have to understand when you get a UOA with that factored in, the lab will most likely tell you as well, that your TBN number could be skewed from the fresh oil added as well as possibly the viscosity, so it might not totally tell the story of how that oil is protecting. But in that case if everything is lookign good anyway, lol then it can't be doing that bad no?
I've read about guys who even blend diff oils for their engines because I am assuming they want to get the best of both worlds, such as some that have a more robust additive package, with some that seem to shear less, whatever you get the idea. I haven't yet become brave enough to turn my truck into a guinea pig for that.
On a final note, the MMO (marvel mystery oil) that the mechanic I know uses, he likes it, I'm not sure I made that clear, as I said before he uses super cheap oil and throws that in there with it and says it does a great job.
Oh, for the Royal Purple guys and gals, I have seen it in wal-mart for like 6 something/quart. That might be cheaper than other auto parts places, not sure.
Ok, a final, final note, really, if you want to look at a great site that will definitely be an educational experience on automotive lubrication, take a look at www.bobistheoilguy.com their forums there have UOA's, VOA's on diff fluids, discussions on all the diff oils. Very interesting IMO. I recently became a member over there.
Oil Tech
Posted: Sep 15 2007 at 3:03pm | IP Logged
thanks guys. I live in Canada, so the "MADE IN USA" means noting to me
really.
I do realize the benefit of topping up my oil with 100ml of fresh oil may
skew the test scores, but the keep in mind it is going into another 5L!
Also, isn't the filter supposed to catch all the things that the lab is looking
for? Seems to me that the filter and the oil would have to fail in order to
show up in the tests?
I have been to the "bobistheoilguy" site many times and it is so huge it is
just very hard to navigate. I wasn't able to actually find much there. I
thnk I have to be a member to get the full access. All I got was a write up
on air filter testes and a couple of tidbits on Lucas Oil. Maybe I did
something wrong.
I was also talking to my gif's father last night at dinner and the whole
family is die-hard chev fans. He also follows the oci recommended by his
van's olm. He has 136,000 kms and still counting. It seems like around
12,000 kms per change. He just takes it in and they use whatever they
use, and I doubt very much it is synthetic. so I might just let my gf go
and follow her olm as a guide and see what happens. Quuestion is, do
the car people make more money from parts or oil? What happens just
after warranty? We would have a vey strong case if we could prove we
foloed al their guidlines for oci's. I have no doubt that the car will last
past warranty following the 12,000 kms oci. But will it ever reach
400,000?
I am understanding that when the age old adage of every 5,000kms
(3,000 mi) oci was started atthe dawn of internal combustion ingines, the
available oils wer no match for today's products. Even our worst dinos
would kick the ass off the best old time oils. So maybe Chev is right to
finally lead the way to dispelling the old oci myth. Good for them. So if
regular ol can actually go 12,000 kms then I have no trouble at all
believeing that synthetics could go 40,000 kms without a hickup. trouble
is calcualting for driving conditions. I most certainly do not drive in ideal
conditions. I drive very rough and dusty roads every weekend (300 km +)
and I also commute approx. 40 km perday. Throw in a smattering of
approx. 800 kms of highway driving in the mountians every weekend and
there you have my typical month.
I'm still not going 40,000, kms, maybe the 35,000, max. But agina
depending on the oil analysis.
I did learn about the lab that Synth talked about and since it is owned by
Amsoil I would use them as a last choice. I want impartial information.
Just common sense.
After my test with the mid-grade oil I am goin to try the top of the line
from amsoil and maybe the high efficiency stuff. I have lots of time to
decide since I only have about 5,000 kms on this oil now. So posting
results will be slow, just so you know.
