Subject Topic: low tire pressure indicator Post ReplyPost New Topic
old sage
Posted: Jan 18 2009 at 3:21pm | IP Logged Quote old sage
With the low temps that hit the mid west to the east, i'm sure that tire pressure dropped and those of us with low tire pressure indicators saw the little light on the dash go on. Well, i put air in the tires close to the 35 lbs of pressure called for on the tire info tag. drove the distance and speed the owners mannual called for to make the indicator light go out and it is still on.  owners mannual says if it stays on go back to the dealer. anybody on the forum know how to reset the indicator without a trip bak to the dealer?  thanks in advance cheers,
old sage
Back to Top View old sage's Profile Search for other posts by old sage
Posted: Jan 18 2009 at 3:45pm | IP Logged Quote frontierguy
Some have to be driven more than others. You may also have a "NO DATA" code stored due to no data from one of the sensors. Is the lite on steady or flashing?
old sage
Posted: Jan 22 2009 at 12:41pm | IP Logged Quote old sage
thnx again frontierguy for your help. i have been driving all over the wash/balt area at 0 to +65mph and the low tire pressure light is still on. it is on steady not flashing. have to go along with your no data code from the sensor. let the dealer fix it. cheers
the old sage
Posted: Jan 22 2009 at 8:12pm | IP Logged Quote frontierguy
old sage,
Make sure you are using an accurate tire guage. If in doubt, go 3-4# more and see if lite goes out.
Bads Crew
U.S. - Maryland
Posted: Mar 01 2009 at 10:01am | IP Logged Quote Bads Crew
I had the same problem. What happen in my case was that I razed the pressure in the tire when it was cold. The light went out and all worked fine while running around town but when I ran at highway speeds the tires warmed up and made the pressure rise above the recommend tire pressure and the light came back on. It took a few stops to tweak them out but once I hit the mid range pressure the light went out and stayed out.
When I put on new skins this Spring I am going to have them filled with Nitrogen to stop all the temperature related pressure adjustments.
http://www.innovativebalancing.com/Nitrogen.htm
White 2008 Frontier Nismo
Back to Top View Bads Crew's Profile Search for other posts by Bads Crew
Posted: Mar 03 2009 at 8:10pm | IP Logged Quote frontierguy
Too much pressure will not make the lite come on. They come from the factory with 45+# and the lite is not on.
mesillynotyou
U.S. - Tennessee
Posted: Apr 12 2009 at 2:50am | IP Logged Quote mesillynotyou
if one is off a couple of pounds from the others I have had mine come on.
Back to Top View mesillynotyou's Profile Search for other posts by mesillynotyou
